I am writing regarding some results using the HEC 22 loss method. We are working on a sewer model using the explicit calculation engine and HEC 22 loss method by request of our client, so this cannot be modified. We calibrate the model using field data basing on flow, depth and velocity. We have found cases in which depth results show an unexpected jump due to HEC22 losses. See the following screenshot:
We wanted to ask you about these jumps because it does not seem to conform to real behaviour, and there is nothing similar on any of our meters.
In short, why do these jumps appear? Is there a real explanation?
Regards.
Hello Luis,
What sort of continuity error are you getting when you compute the model? You can try lowering the Routing Time Step in the calculation options properties to see if that helps. Try a value of 1 second and see if the results look better. You can also find some additional things you can try at this link.
If that doesn't help, it would be useful to see a copy of the model to have a better understanding of what is happening in the system. This link has the steps on how to send the model files to us.
Scott
Hello Scott,
Already have 1 second Routing Time Step calculation. These are the model options and summary results:
I have sent you the model.
In looking at your earlier screenshots, I don't see a scenario with the same name in the model you provided. I am looking at the currently scenario in the model you sent, which is "Tiempo_Seco_Calibracion_20170417_kcr=0.33-1.80-1.62_Kn=+0.0055". There are some instabilities, but not like what I see in the screenshots.
Could you confirm that the correct model was sent? If so, could you let me know what scenario you are looking at?
Apologies for the late reply but I couldn’t work in this project for a while. I have sent you a new model with one scenario, where you can see some graphs with problems like the ones explained in the first message. In this case there are bigger jumps:
This issue may be because the conduit has a hydraulically steep slope. This link has some information on this. This forum post has some additional information as well.
