OpenFlows FLOOD ; 2d modeling floods
How to make dtm model in openfloods flow??
Which files does it support for import data and mention in those files what data does it consist.
I m using this model for urban floods purpose using  sewergems storm data as source.
If anyone knows the procedure please share pdf file and video demostrating it.
Parents Reply
  • Hello Syed,
    In OpenFlows FLOOD you can currently load this type of information mostly in shapefile format. Here is a list of some supporting files and the corresponding format:
    • DTM -> XYZ, Raster (asc, adf, TIFF, GeoTIFF, etc)
    • Buildings, roads, etc -> Shapefile, WKT, ASCII
    • Land cover/land use -> Shapefile, Raster
    You can load this information in the Map menu using the corresponding buttons "XYZ", "ESRI Shapefile", "Raster". For ASCII and WKT points, polygons and lines use the "Geometry" button.
    Luis
