How to make dtm model in openfloods flow?? Which files does it support for import data and mention in those files what data does it consist.
I m using this model for urban floods purpose using sewergems storm data as source.
If anyone knows the procedure please share pdf file and video demostrating it.
Thank you for response .
What about uploading supporting file like master plan of the city.
Which files doed it supports.
Hello Syed,
In OpenFlows FLOOD you can currently load this type of information mostly in shapefile format. Here is a list of some supporting files and the corresponding format:
You can load this information in the Map menu using the corresponding buttons "XYZ", "ESRI Shapefile", "Raster". For ASCII and WKT points, polygons and lines use the "Geometry" button.
Luis
