hydraulic grade line
Hello Folks ,
Kindly i have a question related to Sewer-gems Software , my question is about the hydraulic grade line in a sewer networks that modeled throughout Sewer gems or sewer cad .
The Hydraulic grade lines have a small jump before manhole entrance , even-though the inlet pipe and outlet pipe has the same : diameter , flow , slope , partial full flow percent
my question why this small jump happens ??
  • Hello Khalid,
    Is there any inflow at this node? Is there some sort of control structure or flag gate assigned to the conduit upstream of the node? If so, this might account for this.
    If not, we may need to see a copy of the model. To send this, please use the steps in this link.
    Scott
  • Hello Mr Scott ,
    No there is not any of the following above , but this problem happens when i choose ((Flow Profile Method : Back Flow Analysis )) , on the other hand when i use ((Flow Profile Method : Capacity Analysis  )) this Jump before manholes disappear and things going normal .
  • Khalid,
    Please check the Profile Description of these two pipes. Most likely you have two supercritical pipes in series, which will cause a discontinuity because of the frontwater analysis performed, as described in this article:
    Hydraulic grade discontinuity at steep pipes or across nodes (frontwater analysis)
    Basically the upstream pipe tries to approach normal depth on the downstream end, and the next pipe needs to start at critical depth on the upstream end, which is higher than normal depth because the pipe is hydraulically steep.
    Jesse Dringoli
    Bentley Systems, Inc.
    Answer Verified By: Khalid Hilu
  • Mr Jesse ,
    You are totally right , the two successive pips is flow in super critical condition , when the two pipes are in sub critical flow condition this discontinuity disappear .
    But on other hand , in hydraulics i know that the jump should occur when the upstream pipe have a super critical flow and the down stream pipe have a sub critical flow in this case the jump will occur .
    in our case we have two successive pipes with same condition " super critical " so it is supposed to not have any jump  ??
  • We do not support an option to turn off the hydraulic jump that is modeled when a supercritical reach is interrupted by a manhole.  In your case, I expect the software to yield consecutive S2 profiles. Alternatively, if you deem the junction between your two pipes as hydraulically insignificant (lateral inflows, junction losses, etc), then you could model your reach as one continuous pipe instead of two.
  • Khalid,
    The "jump" here is not the same as a hydraulic jump that would occur along the length of pipe when a hydraulically steep pipe transitions to a hydraulically mild sloped pipe.
    The "jump" here is due to a jump from near-normal depth up to critical depth, and is an artifact of the way that the calculation is performed - it performs a "frontwater" analysis with steep pipes, where it starts at critical depth on the upstream end. See the previously sent article for more information.
    So, although this may look strange, it is expected and you can essentially ignore the "jump" that occurs, or combine the two pipes together.
    Jesse Dringoli
  • Thank You Mr Jesse i got the point now , Perfect clarification by you
    wish you a nice day .
Reply Children
