I'm importing a large set of network data into stormcad from shp files. The shape files contain full information of Catch Basins, Taps, Outflows, Conduits, Laterals, Catchments including connectivity information (from node, to node, catchments' outfows, taps' outlows). I cannot find the field to use for importing tap's Referenced Link and I cannot paste any data in the Flex Table Referenced Link column either.
Hello TH GE,
Taps and laterals are typically created in reference to property connection elements. Do you have these in your model as well? If not, taps and laterals are not likely be to useful in your model.
If you do have property connection elements, you can also create taps and laterals using LoadBuilder. However, if you still wanted to import taps and laterals using ModelBuilder, you will need to include a referenced link for the tap. This will be the conduit that the tap is associated with. If this is not included in your shapefile, the LoadBuilder method of creating the taps and laterals may be better.
Scott
One of my colleagues just reminded me of a tool you may be able to use instead of LoadBuilder. If the taps are in the model, you can use the Assign Taps to Link tool. This can be found by going to Tools > Tools > Assign Taps to Links, or by searching for this in the Ribbon Search. So if the referenced link is not included in the shapefile, you may still be able to get this properly assigned once the taps are in the model.
Answer Verified By: TH GE
Hello Scott
Thank you for your replies
I don't think Load Builder is available in StormCAD (I have 10.02.00.55 installed). I couldn't find "Assign Taps to Links" tool on the ribbon but when I used Ribbon Search it came up and worked just fine. I still don't understand which Tap field to use in Model Builder when Tap shp file includes Referenced Link information.
Theodore
The LoadBuilder Tool is used to assign sanitary loads to manholes. Since StormCAD is only used for storm-water conveyance the LoadBuilder tool is not provided. However you can find the same in SewerGEMS under the Tools Tab.
As per Scott's response to "Assign Taps to Links", you can find this under the Tools Tab >Tools > More > Assign Taps to Links.
This will assign the taps to the nearest links.
TH GE said: I still don't understand which Tap field to use in Model Builder when Tap shp file includes Referenced Link information
When taps are laid out in the network and assigned to a particular link the "Referenced Link" property gets populated with the label of the referenced link (conduit).
See the below snapshot of the tap properties;
In ModelBuilder you have to assign this property so the "Referenced Pipe" field.
Hope this helps.
Yashodhan Joshi
