Hello guys,
Can anyone explain to me the shortest way to merge nodes in close proximity all at once.My tolerance distance is zero.
Hello Mulongo,
There is no direct tool to batch merge nodes in close proximity, but there are several ways with which this can be accomplished.
You can use either a ModelBuilder run, or edit the data in a GIS environment or use the Network Navigator along with the existing node merging tool.
The following article provides a solution to this. See the section "Batch merging nodes in close proximity (multiple areas)" for details.
Merging Nodes in Close Proximity
Hope this helps.
Yashodhan Joshi
Thanks, Yashodan for the reply. Can we get such a tool to ease our and shorten our modelling time?I understand that there are certain mistakes that might happen when editing the pipeline routes in the GIS environment
I created an enhancement for this, for the developers to consider in a future release. If you can send me a private message with your account information, I can create a service request and attach the enhancement to that. Then you will receive a notification if or when the feature is available.
Scott
OK Scott,
Thanks, the introduction of the tool will help a lot. I sent you a message
