Are there any custom reports delivered with SewerGEMS Connect Edition Update 2?
A few agencies we submit to are familiar with a hydrocad report format. With custom reports can information similar to the attached be shown? Thanks.
PDF
Brian,
Have a look at this wiki article that explains how to customize flextables and other reporting tools. It should help you achieve what you're looking to do.
Mark
Hi Brian,
Since every modeler will have very different needs and standards, we do not include any example/template Custom Reports in the Custom Reports feature. However, as seen in the article Mark provided, you can certainly create a custom report similar to the example you provided, by adding sections for the plan view, then various flextables and graphs as needed.
If you need detailed information about every catchment, and you are doing simple site design, consider using PondPack. PondPack includes a large amount of reporting detail in its Report Builder tool, which can similarly be set up as a template.
Once you have the Custom Report set up the way you like, you can either save it as part of a seed file, or use the Export button to save to a .RPTX file which you can then import into another project. See the section entitled "Reusing Custom Reports" in the Custom Reports wiki article.
