Hello Bentley,
I created stormCAD model for pipe design.In my model there are few channels where I need to design infiltration trenches.I saw LID under SewerGEMS can do that.However, I have few questions.
Questions.
Can I import same model in sewergems including same setup with rational flow to design infiltration trenches or I have to use SCS method.
Please find the following attachment.
Thank you,
Hari
Hello Hari,
The mentioned file is not attached herewith.
Please note that GVF-Rational solver does not support design of low impact development elements. LID works with implicit - dynamic solver.
And rational runoff method is applicable only with GVF-rational solver, so you may not be able to use it with Implicit solver and LID. You can use SCS method / modified rational method or other options of runoff method.
Low Impact Development (LID)
Sushma Choure
Bentley Technical Suppport
