I'm running into an issue with an EPS simulation that I'm running and can't seem to resolve an issue. I'm running the model for week long time period and will eventually attempt to run constituent analyses with it for an emergency chlorination program. The issue I'm running into is with 1 of the 3 reservoirs in the system, this reservoir has a tendency to crash the model when it needs to be filled. The other reservoirs seems to be running fine. I think with this issue resolved and some refining, the model will be ready to proceed forward (I'm hoping). I've linked the model for help in obtaining assistance.
One complex thing that may be a source of this problem is that there is a joint use reservoir that is shared between this system and an adjacent system. We do not have SCADA data for that system, but we eventually decided upon using a FCV with a pattern based hourly demand that will call of water to and from this reservoir.
There are many controls in this system and am happy to walk someone through them if they can help me. Thank you for any assistance or guidance you're able to provide.
Please call me at 425-951-5466 if calling is better than the forum.
Here is the modelto Bentley (Model).zip
Gregg Davidson,
I've downloaded your model for analysis and will post back here with the results I find unless a phone call would be more appropriate.
Thank-you,
Larry
Helo Gregg,
I had a quick look at your model, the controls on tanks are not setup properly, you should manage controls such that the tank never reaches 100 % full. In that case it will close the adjacent pipe, with unrealistic hydraulic grade lines in the model and network unbalanced issues.
In your model when tank reaches 100 % it closes the adjacent pipe changing the hydraulics of the model. E.g. tank - Crest Reservoir is full 100 % at multiple time-steps.
Sushma Choure
Bentley Technical Suppport
This is a helpful tip, but i'm still not able to resolve some of the underlying issues with the tanks. I've updated my model accordingly and tried to revise some of the issues I've been running into. Here is the updated model that I'm currently working with. The EPS Calibration Scenario is the one I'm most particularly concerned with.
EPS Calibration.zip
Hello Gregg,
Here are my comments, please check following,
Hope, this helps.
