Visualizing water age results
Hi all,
Has anyone come up with some creative options for visualizing water age in GIS? If you're only looking at a small area, simply making a color/size-varying symbology from exported junction or pipe tables is fine. But, for a large area, junctions get too cluttered or shorter pipes become too small to see. I've seen heat maps made from junction results, but you have to be cautious with the interpretation, as for instance open areas with no infrastructure get filled in with values from the interpolation.
This additionally would be in the context of showing improvements in water age, so ideally a clean way to have side-by-side maps with noticeable differences.
Nina
