Hello ,
I am trying to update the demands for an existing model. I created a new scenario and created alternate topology and made all the existing customer meters inactive.
I have 7724 customer meter records that need to be imputed into the model. After using model builder and synchronising it I found that 5075 elements were created and 2464 element were updated.
Can updates happen to elements inactive? How else can I avoid this from happening.? I also noticed that the 2464 elements that were updated are inactive in the current scenario. And also the base demand is different from my input shape file.
Thanks for your help in advance.
Indu Appan
Water Systems Engineer
Power and Water
Darwin, Northern Territory
Australia
Hello Indu,
You have filed a Service Request (#7000885671) for the same issue.
We can continue the problem resolution via the Service Request.
Yashodhan Joshi
