Pipes length adjustment in Hammer?
Dear All,
In my Hammer model I have a lot of pipes length adjustment vary from 3.8% to 1000%
i need to know, what is exactly the influence of this adjustment on the output maximum and minimum pressure accuracy.
thanks
  • Hello Mohamed,
    The length adjustment in HAMMER depends on your wave speed and the time step considered for analysis.
    For E.g. if a pipe is of 150 m with a wave speed of 200 m/s and a time step of 1 sec then the pipe length would have to be increased by 50 m (150+50 = 200 m) so that the transient wave can travel the distance in 1 sec.
    Here is a relevant article which can guide you on length and wave speed adjustments.
    Understanding length/wave speed adjustments and their impact on results
    In general a smaller time-step will give you more accurate results. This is because a smaller time step leads to fewer adjustments in lengths. Whereas a larger time-step can increase the lengths substantially leading to skewed results which may not reflect the true conditions in your system.
    Hope this helps.
    Yashodhan Joshi
    Answer Verified By: Expert
