I am trying to optimize a hydraulic network in watergems using darwin designer. But I am getting an error "Feasibility check failed. No feasible solution exists with current input data". Steady state analysis is being used. Although I am able to analyse the network with pre-defined pipe diameter. Could anyone please help me out?
Hi anujkumar,
You will find a bit more information if you do a google search for that message.
Here is one of the links that comes up:
https://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/40704/feasibility-check-failed-no-feasible-solution-exists-with-current-input-data-for-eps-analysis-with-time-from-start-0-00-hrs
Best regards,
Rob.
Hello Anujkumar,
This error message implies that there are data entry issues in the model input data fro Darwin Designer.
Please check the input data of Darwin Designer step by step, the below technote will help you with or technote provided by Rob.
Using Darwin Designer to design pipes in WaterGEMS
If this does not help then please upload model files for our review.
Sharing model files
Sushma Choure
Bentley Technical Suppport
