This is probably a stupid question but for the life of me I can't figure out how to delete this stupid legend.
If I press delete al it does is de-select it. Same happens if I use the red cross button. When I right click the delete option is greyed out. I have checked the element symbology tab, there is no option to delete the legend on any of the relevant symbology styles.
I don't understand why pressing delete simply doesn't delete it.. is it a bug?
Hello Ryan,
To delete a legend from the drawing area, you need to right click on legend field in element symbology and select remove legend, the same way you added the legend initially to create it.
By right clicking on the legend in drawing area you can either zoom or scale it only.
Sushma Choure
Bentley Technical Suppport
That's a strange feature to have that you can't simply delete Thematic tables, I can't figure out why Bentley would do that.
Regardless you're solution does not help. I have already right clicked on every thematic in element symbology and none of them give me the option to remove the legend. (I did not insert this legend)
My apologies I didn't notice that screenshot mentioned contour legend not element symbology legend.
To delete a contour legend, you need to go View > Contours > Right click on contour label - Age (Maximum) > Remove Legend.
Answer Verified By: Ryan Catling
I've never even used contours.. but it worked
