Pondpack Scenario comparison tool
 I have pondpack model with Pre & Post development scenarios for the 2yr, 10yr, and 100 yr storm events. I want to compare all the scenarios at once after doing a batch compute and see the results, but can't find the scenario comparison tool. What is the process for scenario comparison and where is the 'scenario comparison' tool  ?
  • Hello Ekene,
    The Scenario Comparison tool is not included with PondPack at this time. Even it is was there, this tool is used more to compare how different scenarios compare to each other in terms of set and use of alternatives. For instance, you would be able to compare two scenarios to see how the alternatives different between them and see what properties are different between them.
    This doesn't extend to results though. The best way to compare results between scenarios may be to use either Report Builder for multiple scenarios (for numerical results) or by graphing results. As an example, if you compute post-development scenarios for a 10-year and 100-year storm, you can graph the runoff from the catchment or the pond results for both scenarios in the same graph by selection both scenarios in the Graph Series Options. Similarly, you can graph runoff from a catchment for pre- and post-development scenarios in the same manner. This link has details on this.
    Scott
Reply
  • Hello Ekene,
    Scott
