Automate the SYNC-IN from modelbuilder in ArcGIS
I sync WaterGEMS and SewerGEMS with a GIS with modelbuilder.
In ArcGIS (10.6.0.831), using the Bentley WaterGEMS (10.01.01.04) (64) V8I ModelBuilder i can transfert the data from the MDB DB (OLEDB personal geodatabase connected to WaterGEMS ) into the ESRI File Geodatabase through the SYNC-OUT using the "Label" as a key in SQLServer.
Its work well, but i would like to know if its possible to automate the 'Sync-IN' with a periodic execution e.g with python or ArcPy ?
