Hi All,
Im using civilstorm Pond maker, anyone can explain to me why the result so many curve?
Thank you.
Hello Gregorio,
The different curves represent different tailwater levels when you are analyzing the rating curve for the riser. These tailwater conditions depend upon you minimum and maximum head-water conditions specified for the Composite Outlet Structure. See the below article on using the PondMaker tool for more details;
Using PondMaker
Another article which you might find useful;
What do all the lines in PondMaker step 4 represent?
Hope this helps.
Yashodhan Joshi
Thank you
