Hell all,
How to model a valve closure time say 90% of closing with in some time and remaining 10% with in some time in water hammer software. So that surge pressure will be with in design pressure pipe.
Satish kumar B N
Hello Satish,
To model valve closure of the valve you can use the operation pattern for the valve, (Components > Patterns > Operational (Transient, Valve) ).
Here you can specify the time for valve closure and then % of relative closure of valve, as seen in below screenshot.
There is a sample mode of valve closure of TCV - "Valve_Closure_Example" in the installation folder, which you can use as a reference for modeling.
C:\Program Files (x86)\Bentley\HAMMER\Samples
Here is technote about modeling valve closure, for your reference.
Modeling Reference - Valve Closure
Sushma Choure
Bentley Technical Suppport
