I am trying to export watergems file to excel. I have getting repetition of same pipe label & node label in the exported sheet.For reference , Exported file is enclosed.Please review & provide solution.
Jakkamsettivaripalem.xlsx
Hello Ankr,
This is likely displaying different time steps for that pipe. If you look at the "Timestep" column, you will probably see the times change.
For more information and other ways of exporting to Excel, see the following link: Export data to an Excel spreadsheet. For instance, if you are concerned about a single time step, you can export flextable data to Excel. You will need to use the Time Browser to make sure you are on the time step you are concerned about.
Scott
Thanks . It was helpful.
