PondPACK_Volume
 Hello Bentley,
Attached is the routing table from Pondpack. That table didn't show my desired water elevation from where I can see my max storage volume.
Suppose in attached table, if I want to see max storage volume in elevation 1125 ft or 1127.5 ft, How can I see that?
Thank you so much for your time.
Hari
  • Hello Hari,
    The column at the far right, "maximum storage", shows you the pond volume, at the respective "Computed Max Water Surface Elevation". So for example for your 10 year event, your designed outlet and pond result in a maximum water surface elevation of 1127.38 ft, which corresponds to a volume of 8805 ft^3.
    If you want to see pond storage volume at specific elevations for your pond, you can right click on the pond (after exporting your design from PondMaker) and choose "Pond Volume Results". You may need to add those desired elevations as new rows in the pond's elevation-area or elevation-volume table. See more in the following article from our Wiki: Viewing pond volume and area results in PondPack
    If I have misunderstood your request, please provide further details on what you are looking for, and what you need to accomplish with it.
    Jesse Dringoli
    Bentley Systems, Inc.
