For some reason when I generate contours based on available fire flow, there are gaps in my contours. I have played around with the maximum/minimums and increments but nothing seems to work.If I color code the junctions based on AFF, they all work, even in the areas where the contours do not display.
Other calculation results display contours overt the entire model (such as static pressures) but AFF does not.What am I missing?
Hello Erik,
Do you have a screenshot of what you are seeing? It would help visualize what you are seeing.
Scott
Do you mean the part in the upper left? If so, what are the values relative to the others in the area. It may be that the area is relatively "flat." If that isn't the issue, seeing a copy of the model may help. This link has the steps on sending the files to us.
Thanks Scott.
You were correct. That area just happened to be very "flat" when it came to AFF. I changed the increments to 0.1 and finally got some contours to show up.
