Hi, can you convert the two old watercad files I've uploaded.
Thank you.
Dylan
Dylan, I tested the two WCD files you provided and can confirm that they are from V7 models and the .MDB files that would go along with them are missing. If someone else sent these to you, they might have been blocked by an email server for example. As seen in the article that Yashodhan provided, you can directly open V7 models in the latest versions of WaterCAD and WaterGEMS, by opening the .MDB file.
If you need to preserve the presentation settings (color coding and annotations, primarily), you will need to provide the .WCD and .MDB files.
