Please find the attachment which is showing error, is it anyway connected to figure 2
Hello Niyanth,
The first error message indicates that one of the supporting files has become corrupted, so you are having issues with the model. Can you please try following?
If this doesnt help then please upload the model files with all supporting files in the folder, for our testing.
Sharing model files
About second error, it could be related to the first error as it shows that there are -1 manholes in the model, which is not possible, please upload files for further comments.
Sushma Choure
Bentley Technical Suppport
Answer Verified By: Niyanth Karanam
Thank you, :).....
The problem has been solved after Compacting the database, but few conduits went missing when opened the file. As the missing conduits are less in number i drew them again.
