I am working in a model that someone else created. It appears that they brought in all of the isolation valves as check valves.
I know that the Skelebrator can change TCVs, GPVs, and PBVs to Isolation valves, but is there a good way to do this within WaterGEMS with Check valves? If not, I know that I can export and reimport the right way.
Mike,
I found a slightly easier solution for you that uses a combination of two tools.
Here are the steps:
1) Batch morph the check valves, which I'm assuming are the check valve element and not the check valve that is an attribute of the pipe, to a TCV, GPV, or PBV.
2) Use Skelebrator to change the new valves to isolation valves.
3) Use the assign isolation valves to pipe tool, on the Tools menu, if necessary to associate the iso valves to the pipe.
Mark
If that doesn't work use the export process.
