Is there a way to customize a junction flex table to only show the active nodes?
Hello Andrew,
Below wiki explains how to customize flex table to show only active elements, you need to apply filter in the model on 'Is active column'.
Filter FlexTable to only show active elements
Sushma Choure
Bentley Technical Suppport
Answer Verified By: Andrew Schultz
