Flow in pipes
I'm new to WaterCad and I'm wondering if it can help me with my problem. I have a tank which has an exit line that branches into three lines and I want to know the flow that would exit my tank and the amount of flow that passes through each pipe. The three branches have different diameters and end at different elevations. Do anyone has any advice?
Thanks in advance.
