Hello,I have built a large water supply model with 27 zones.
I would like to model some zones without computing the entire model.
Can I create sub-systems ? Would I use Active/Inactive topology to effectively turn off / turn on different zones when i'm modelling ?
Thank You,
Hello Tracey,
Yes you are on the correct track, you can make zones inactive which you don't want to model at the moment so those elements will not be considered for modeling.
Here is reference for using active topology management.
Active Topology Management
Sushma Choure
Bentley Technical Suppport
Hi Sushma,
Great, thanks very much.
This is my logic:
Base EPS (Trunk and all zones)
From these I was going to create Scenarios
Issue: I'm trying to create the above Alternatives however I can't work out how to select just the Wingham Zone elements or just the Irkanda Zone elements.
The Active Topology Alternative set of tabulated flextables don't show the Zone column and I can't add the Zone column. I've tried a work around by creating a Selection Set of the entire Wingham Zone containing all it's elements but I can't seem to use the Wingham Selection Sect to create the Wingham Alternative.
Can you help ?
Thanks, Tracey
What you would do is
Alternative will not have zone columns, flex tables will have zone column. With flex table approach you can open flex table on selection and make elements inactive but you will have to do it separately for pipes, junctions etc.
