HI!
I have the most recent verison of WaterCAD, and faced an issue, which stand for every model I've tried on. It was present in former version of the software, as well as I remember, after CONNECT update 1, but I've missed to report it due to the easy workaround. It is intrigue, that it only affects pipe color codings... Here is the example:
Example_4 original. Color scale: diameter
Greyed out inactive topology:
After Compact database ( I crossed some pipes with yellow color, which should be greyed out):
On a database level, it works flawlessly. They are considered "inactive" in both simulation and a flextable.
I've made a workaround by adding an additional color coding for "is it active?" property with the same grey color. Although, It is absolutely not how it should behave.
Attila Bibok
Hello Attila,
Thank you for reporting this bug which I could reproduce, I have logged defect for this, reference number is #1036938, which shall be considered for future release of the product. Also created service request so you are informed when the defect is resolved.
Sushma Choure
Bentley Technical Suppport
Answer Verified By: Attila Bibok
