Hello colleguies,
I would like to know if there is any way to connect two conduits without manholes. what is the best way to simulate a for example a conection with some kind of serwer fitting, pipe crosses for sewerage systems..???
I was thinking in transition tool, but I'm not sure if it is what I'm looking for...
Thanks for your help.
Best Regards
Hello Carlos,
Having a transition element between conduits would be the correct way to model conduits without manholes at either ends. Transition elements are generally used to model connections between conduits (like a tee or an angle) without a manhole. See the below article which explains the differences between a manhole, transition and a pressure junction and their appropriate use cases;
Pressure Junction vs Transition vs Manhole
Hope this helps.
Yashodhan Joshi
Answer Verified By: Carlos Andres Bellido Soliz
Thanks for your support Yashodhan.
Your explication was clear.
