I have site data for PRV's in my model.
For flow modulated PRV's I have data such as;
PRV-1
and for the time modulated PRV's I have data such as;
PRV-2
I want to ask that is it possible import this data from model builder and if it's possible how can I import this data from modelbuilder.
Controls can be imported, but the source data must be in a specific format. See: How to import and export controls between models in WaterCAD and WaterGEMS
The article that Yashodhan provided has some information on importing valve patterns, but for a PRV or PSV if you want to change the pressure or HGL setpoint over time, you would want to use the "Pattern (valve settings)". This consists of a table of time vs. multiplier, so your data source would need to have a column that has the multiplier needed to achieve the desired pressure or HGL setpoint (the multiplier multiplies against the initial setting).
Answer Verified By: Mehmet Ayan
Hi Jesse and Yashodhan
Thanks for your help.
"Option 2: 08.09.400.34 through V8i (and for importing controls from a spreadsheet)" worked for us and it is suitable for our project.
