Sir,
I developed a model using WATERGEM for the pumping water from Reservoir (Sump) to 11 Elevated tanks located in the Habitations. The analysis report shows reverse flow from some of elevated tanks against pumping.
Can WATERGEM be used for analyzing pumping main to feed water to elevated Tanks or only for distribution network.
Expecting your able support Early.
Dr.K.Ravichandran,M.E.,Ph.D.,
Heelo Dr. Ravichandran,
Yes, you can use WaterGEMS to design and analyze pumping stations supplying to ESR's. As far as the reverse flow is concerned, check your pump head and discharge values and confirm if the pump orientation and downstream pipe are both flowing "towards" the elevated tanks. Also check the orientation of the connecting pipe. Ensure that the start node is the "pump" and stop node is the "tank". See the below article for more details on this;
Why do I sometimes see a negative flow through a pipe?
Let me know if this helps.
If this does not answer your query, please share some screenshots (maybe showing the reverse flow) to understand.
Yashodhan Joshi
Hello Mr.Yashodhan Joshi,
Thank You for your immediate response.
The Pump has been chosen with discharge as the total quantity required to fill all the eleven ESR's simultaneously in 12 hours of pumping and the head as to feed water to the highest elevated ESR among 11 ESRs.The orientation of pump is also towards downstream of pumping main.
If possible Kindly provide a developed model and analyzed results which will help me to proceed in better manner
How to select the type of pumpset type 1) Submercible 2)Centrifugal 3) Horizondal Split Casing etc.
Hello Dr. Ravichandran,
ravichandran krishnasamy said:How to select the type of pumpset type 1) Submercible 2)Centrifugal 3) Horizondal Split Casing etc.
Submersible pump or a centrifugal type pump is nothing but a positive displacement pump which is modeled in WaterGEMS. Horizontal split casing is the casing of the pump and is not specifically modeled in WaterGEMS. Since WaterGEMS is a hydraulic modeling software the hydraulics concerned with the pump such as head vs flow relationship, power and pump efficiency, etc. are the model parameters.
If possible, please share your model so we can have a look at it and determine the problem (if any). See the below link for sharing model files;
Sharing Hydraulic Model Files on the OpenFlows | Hydraulics & Hydrology Forum
Hope this helps.
WATERGEM.rarKindly find an attachment of model developed
This is not a single question but rather covers numerous issues in pump station design. Let’s go through each of them.
Bentley Systems provides software for pump selection and station design. We are not an engineering company that provides a design. If you do not feel comfortable doing this type of design work, you are better off hiring a consulting engineer who is experienced in this area and work with that individual/company. If you are doing this work yourself, Bentley provides a variety of training material for performing the hydraulic and energy calculations.
