Pump Not Delivering the Designed Flow in WaterGEMS
I am having a pump at the downstream of the reservoir and it is supplying to the two tanks.
The problem is, I have set 1 point pump definitions with the design flow of 7.75 ML and the pump is delivering just 7.63 ML. I am unable to find out why there is a difference of .12 ML in this case.
Also, does initial level of tanks play any role in this?
  • Hello Chetan,
    Thank you for uploading the model files (via private message).
    As mentioned by Dr. Walski, if you need exact flow coming from pump then you need accurate pump curve from the manufacturer. Withe single point pump curve the results will be as per the head available and will try to deliver the designed flow.
    In your model there are user notifications about FCV cannot deliver flow for most of the time-steps. A FCV will throttle and induce a headloss to regulate the flow through it, but if the flow through it is less than the setting, it will be fully open and you'll encounter the "cannot deliver flow" which is the case with your model.
    See more here:
    What is the meaning of the notification "Valve cannot deliver flow", with regards to a Flow Control Valve (FCV)?
    There is headloss in some pipes in the model, if you are increasing the diameters of trunk line pipes, then headloss will reduce and also FCV will provide the set flow in that case. Still if it doesnt provide the flow then in that case for those time steps flow through FCV is less than the flow setting of FCV and hence it is inactive.
    Sushma Choure
    Bentley Technical Suppport
Reply
  • Hello Chetan,
    See more here:
    Sushma Choure
