Is there any limitation for the number of attributes or the size of the model in Sewergems which can be exported to SWMM V5? When I try to export my model, I'm getting error "index -1 above raw counts" when I split the model (as submodels) and try to export, it does export successfully. Any advice to overcome this issue?
Nishadi
Hello Nishadi,
This error is not seen before, what is the version of SewerGEMS you are using? Is it latest one?
All the model elements / information is getting exported as part of submodels when you are exporting as submodels?
If this does not help then can you please upload model files for our testing?
Sharing model files
Sushma Choure
Bentley Technical Suppport
Thanks for the reply Sushma. The version I used was the latest one. When I try to do the same in a different machine, it worked.
