Dear Bentley Support and Bentley Community,
I have a little problem with my work now and with my current understandings, it will take a little extra time to solve this.
here is the problem.
I have a model on WaterGEM that contains several DMAs. now i need to update (compile) some of the DMA (not all). the problem is the shapefiles i want to use have a different coordinate system with my old model.
i know it is better to change/re-project the shapefiles with the same coordinate system as what my old model has, but i wonder if there are any other ways i can use?
i use the SA WaterGEM by the way.
If the model was originally created in the correct coordinate system and the Shapefile has the wrong coordinate system, you could use ArcToolbox in ArcGIS to reproject the shapefile.
