Hello
I jus need any material vidio or figures that illustrates how the hydropneumatic dipping tube tank work s and when to use it and when to use sealed hydropneumatic tank
Thanks in advance
Eng.serine
Hello Serine,
Charlatte has a video showing how a dipping tube vessel works. Click the "see the film" link here: https://www.charlattereservoirs.fayat.com/en/waste-water-range
Also, you can find a diagram and more information on how to model dipping tube tanks in HAMMER here: Modeling Reference - Hydropneumatic Tanks (the section is near the bottom of the article)
One of the main advantage of the dipping tube tank is that it does not require a compressor or a bladder.
As far as when to use one of these for surge protection - in some cases you may already have a particular tank in mind based on manufacturer information and your judgement and knowledge of the particular system being modeled, and if that ends up being a dipping tube tank, then you can model that in HAMMER. The material for the Charlatte "ARAA" model dipping tube vessel indicates that it is intended for flat profile, sewer force main applications.
Beyond this, selection of surge protection is largely up to your engineering judgment, local standards and other factors such as cost and space. You can set up multiple scenarios in HAMMER to compare the effectiveness of different types of protection and different types and sizes of tanks.
If in doubt, seek research papers on the subject and information from the manufacturer.
