Is there a way to make a map of catchments where they are different colors? For example, a map of the USA has each state bordering another a different color such that one can tell where the state borders are. Currently, all my catchments are green and it is hare to tell their borders. Thanks.
I assume all of your catchments have different areas. So just set up color coding for catchments based on area. That's worked well for me.
Or set up a user defined field and enter some number for each catchment. Then do color coding based on that field.
Answer Verified By: Brian L
That could work. In the note, is there a way to rotate a named view for a report?
Hello Brian,
There is no way to rotate a named view in StormCAD standalone version.
However if you are having integration of StormCAD with Microstation or AutoCAD then you can rotate the model there and save the named view. However once you are rotating the model it will be rotated for all the named views, not for a single.
If this is not what you are looking for, then please elaborate the query.
Sushma Choure
Bentley Technical Suppport
This link has some general information on this, and includes a few other options that may work as well, such as exporting the catchments into a shapefile, adjusting them as needed, then reimporting them using ModelBuilder.
Scott
Just a couple of additional notes:
