WaterGEMS stops responding during the final step of Criticality Analysis.
I am running a criticality analysis where I perform the segmentation by computing the analysis. It works great. Next, I click on Criticality and select the "Run Hydraulic Engine" option and put minimum pressure at 30 psi. Then, when I click the compute button, the system freezes and refuses to work. It's stuck on the third screenshot.
PS: I am trying to perform this only on pipes dia >= 16in
Parents Reply Children
