Sir,
After Validate the model the User notification panel supposed to be display and show the error Report.But it is not display after validate the model,due to this i unable to understand the what are the elements having error.
Pl do needful how to solve this issues
Hello Thangaraj,
Did you receive any error message upon validation of model like there are some issues in validating the model ? If there are no input issues when user notifications panel wont have any messages as validation is successful.
If you dont see user notifications after validation, then you can click on notifications under Home tab or Analysis tab.
Also if user notifications panel is floating then you need to fix its positions so it will always show up, even though there are no errors.
Sushma Choure
Bentley Technical Suppport
If the user notification window is not appearing in the expected location when trying to open it via the method that Sushma described, you may need to reset your workspace to default. See the following article from our Wiki: Properties, Flextables, user notifications, or other dialog is missing or will not open in standalone
