We have redrawn our model using bing map as background it only extracts the distance but not the elevation...
Hello Marli,
The Bing Map feature allows you to trace your network as per actual map layout. This feature does not allow dynamically assign elevations to nodes. To assign elevations to nodes (junctions, pumps, tanks, reservoirs etc.) you would have to use the TReX feature available under tools. Using TReX you can select a contour file or a topography map and assign elevation.
Hope this helps.
Yashodhan Joshi
