How do I delete a catchment area from my model.
Hello Richard,
Do you mean you want to delete all the catchment from your model? If yes then please select all catchments by element type, Home tab > Select by element> Select Catchment, this will highlight catchments in the drawing which you can delete easily.
Or do you want to delete the area given to catchment in catchment properties, please elaborate the issue.
If you are receiving any error while deleting the catchment area please upload a screenshot of that. Which software you are using, what is the version number?
Here is learning resource guide for your reference.
Learning Resource Guide for new users of Bentley SewerGEMS
Sushma Choure
Bentley Technical Suppport
