Dear Team,
I have a scenario, in which one pump is running and seconds pumps start 60 sec later. I have not considered the pump tripping and i need know will there be any pressure variation during the starting of second pump. When i run the analysis for 300 secs, after 60 sec the pressure goes more than the pump head and continue for 300 secs. Theoretically when second pump starts after a delay, a sudden pressure peak should come at 60 sec & continue for few more seconds and then the pressure has to be less or equal to the pump head, but it is not happening. Please clarify why the pressure is (more than the pump head) continue till my analysis?
Note: Pump pattern is assign for starting of second pump.
Abdul
Hello Abdul,
When you say "more than the pump head", what do you mean? Generally speaking when the second pump turns on, the pump that was already running will shift its operating point accordingly, and both pumps will tend to run at the same head (assuming the pumps and the parallel piping headloss is roughly the same).
If the second pump starts too quickly, I would indeed expect a pressure surge as the pump first starts up, and then eventually the pressure would settle down to the expected "nominal" operating point. Meaning, the flow and head should match the flow and head seen when running a steady state simulation with both pumps on. So, I would recommend that you first try doing this (if you have not done so already), to observe the pump operating points in a steady state condition. Then, be sure to use the observed head and flow for the pump in question, as the "head (nominal)" and "flow (nominal)" input fields for the pump (which are required when selecting the pump start transient pump type).
Next, consider the "control variable", which is used to control the "startup" by torque or by speed. See more about the differences here: Pump Startup occurs too quickly / initial upsurge too severe
Even with this configured correctly, there are a few other factors that can occur in the model to cause the final operating point of the pump (at the end of the transient simulation) to not match the expected operating point. See the eight numbered items in the following article under the section "Why is the Transient Simulation not Settling Exactly on the Nominal Head/Flow I entered?": Modeling a Pump Start-Up Transient Event in HAMMER
If this does not help, please provide a copy of the model, exact steps to replicate the problem, and a description of what you see: Sharing Hydraulic Model Files on the OpenFlows Forum
Dear Jesse,
Thanks for the reply. I have uploaded the model in below link: https://communities.bentley.com/products/hydraulics___hydrology/f/haestad-hydraulics-and-hydrology-forum/189768/open-operation-one-pump-running-and-second-pump-starts-60-sec-delay
File Name: Model For Review
Also attached two images:
1. Case-1 : one pump has pressure of 6.5 bar with flow of 500m3/hr. But when one pump running and 2nd pumps starts the pressure graph at discharge header is not starting at 6.5 bar. Please clarify why? It has to run with same head and after 60 secs there should be a hike when 2nd pump starts at 60th sec. then both pump should run with 6.5 bar, but same is not happening.
2. Case-2: This analysis has been carried out with same as above, but i have reduced the flow in FCV and gave 500m3/hr (one pump flow). I got the second graph. But i cannot understand why pressure is dropping down. Please check and clarify.
