I use the program to learn. I finished modeling. But it's always giving this mistake.
"Reference to a deleted" Include Elements "selection set (using all elements instead).
Please help me.
Hello Mert,
What are you computing when you get this message? Messages like this can occur in flushing, fire flow, or just when computing a model (when the downstream pipe is missing from a pump or valve). If the links above do not help, more information on what you are model and when the message occurs may be needed.
Scott
Answer Verified By: Larry Abla
Thank you, Scott.The problem was solved when I selected all elements from the "Include Elements" section in the Alerts section.
