Dear All ,
Kindly i have a question , and i am a little bit confused about H2s Calculations in sewer gems.
First Of all i have seen this article and it understand it well :
Modeling septicity / hydrogen sulfide (H2S) .]
I tried make a comparison between result from SewerGems and an excel sheet with the equation that mentioned in this article but the problem is that the result does not match .
My question is does SewerGEMS use the following equation below euqation or not ?
i need to know what the exact formula that sewer gems uses in calculating the H2S out ?
Hello Khalid,
A similar query was asked on this forum about H2S modeling. See the response here: Hydrogen Sulfide Modeling In SewerGems
You can see the Help section of SewerGEMS for the H2S equation used in modeling under the Theory section.
Let me know if this is what you are looking for.
Yashodhan Joshi
