I have an issue validating this water gem file. Even I am using the latest version of water gem update 210.02.01.06 64-bit it is still showing the same error. Please let me know how to fix this error. I have uploaded the file in the below wetransfer for your reference.
https://wetransfer.com/downloads/27c9ac26b82ff364aaeec9ee0a8f400720191217133430/7c4f30
Thanks & Regards,
V.Ragavendra
Hi Ragavendra V,
I pulled your file and opened your model with WaterGEMS Update 2 (version 10.02.02.06)
I Verified your model
And Computed your model
I see no errors as you mention.
Please run a "Repair" on your WaterGEMS installation
After the "Repair" is complete, open your model and Validate/Compute to see if the errors are cleared.
Please let us know your results.
Thank-you,Larry
Hi Larry,
Thanks for the prompt reply!
As you advised i repaired the software but unfortunately, still I am getting this same issue again.
I am really helpless to fix this issue.
Kindly advise me again.
Would it be possible for you to upgrade to WaterGEMS Update 2 version 10.02.03.06 to see if the problem has been addressed in the updated version? I'm running 10.02.03.06 and still do not see the error you are getting.
Please let me know if this is possible for you.
This is a known issue with opening models saved in a newer version of CONNECT Edition Update 2, and is described in the following article in our Wiki:
Computing model saved in version 10.02.02.XX or 10.02.03.XX results in "Failed to validate model."
The solution is to upgrade your WaterGEMS version as Larry suggested.
