how to design with sheep file with demonad calculate meth rd design .pls any example,or video ...
Hello Sir thanks for your reply sir one more questions how to create a Shep file with arcgis and build a pipe line distribution network design and calculate water demand and *** methords with wartergams step by step
And separately putting a water demand methord. Video and book or PDF...Gide lineÂ
 thanks sir
RegardÂ
Zohaib Khan
Hello Zohaib,
Shapefiles in ArcGIS can be created by using road maps and survey data collected from a surveying agency.
Using these shapefiles you can create a water distribution network using the ModelBuilder tool in WaterGEMS. See the below article for details;
Using ModelBuilder to Import External Data
Demands are generally calculated by calculating the water demands for a particular area. You have to refer codal provisions and standards for your country or the specific area to understand how the demands are calculated. For example if an area has a population of 100 people equally distributed and if the per capita water requirement is 150 liters per person then, total demand would be 100 X 150 = 15000 liters per day or 15 *** per day.
If you are new to using WaterGEMS I would suggest you to go through the learning content we have. See the article below for different learning resources we have;
Learning Resource Guide for new users of Bentley WaterGEMS and WaterCAD
Hope this helps.
Yashodhan Joshi
