Is there any way to change the laber size or Font or orientation? I tried the symbology but it doesn't have these options.
Under Symbology, right click Label (or pick Edit) and then set Height multiplier to whatever you want.
You can also set the x and y off set or pick a selection set of elements to display the label and not the others.
Answer Verified By: Mehrdad Gharibnavaz
See also from our Wiki:
Changing symbol size, text height, or line width for elements in a model
Is it possible to change the font for text in DXF backgrounds and annotations?
