I am trying to model a sewerage rising main from pump station to STP. I am encountering negative pressures at pump station and reverse flow in the entire network, need urgent help to resolve the issue. I am attaching the model files for checking the model.
Many thanks in advance,
Best regards,
Vivek
Muwaileh Foul RM Modelling.wtgpkg.zip
Hello Vivek,
Please check the orientation of the pump. Right now the pump is pumping into the reservoir "Foul PS Wet Well," though the setup of the system would make more sense if it was pumping away from that reservoir. If the pump is pointing the wrong way, you can change the downstream pipe by opening the pump properties, clicking on the property field "Downstream Pipe" and selecting Reverse.
Answer Verified By: vivek@ch2m
Thanks Scott for your prompt response. Much appreciated.
