Hello, I put this model together, but the calculated numbers for total head seem really big. would someone care to take a look at it and see what you think? I would really appreciate it. Also does anyone know if epanet takes into account the bends in the pipes (between junctions) into the calculation.
test-1.zip
Hello Billy,
This forum is for users of Bentley's OpenFlows brand of hydraulics and hydrology solutions which include products like WaterGEMS (for water supply modeling), SewerGEMS (for storm-sewer modeling) and HAMMER (for transient simulation). In additional to these there are several other similar products under the OpenFlows brand for hydraulic and hydrologic modeling. For more information see the link below;
Bentley OpenFlows - Comprehensive Modeling Solution for Water, Sewer, and Stormwater
The total head at a node is considered as the sum of elevation and pressure head at that node. So if the elevation at a node is 10 m and the pressure head is 15 m then the total head would be 10 + 15 = 25 m. The head can be increased by a pump which follows a pump curve to increase head as flow changes.
I cannot comment about EPANET but WaterGEMS does have a property where you can incorporate your losses due to bends, valves and other appurtenances in your pipe for analysis. See the below article for reference on this;
Adding Minor Losses to Pipes
I would recommend you to use our OpenFlows product WaterGEMS if you are looking to model water distribution systems. WaterGEMS is an intelligent software with a host of tools and features to cater to water modeling requirements. From hydraulic modeling to operational strategies; WaterGEMS can provide a holistic solution for your needs. It contains advanced tools such as Darwin Designer for optimal pipe sizing, SCADA CONNECT Simulator for real time modeling and emergency response management. Please see the video below which discusses the important features of WaterGEMS;
The latest version of WaterGEMS is the CONNECT Edition Update 2.3 (v 10.02.03.06). See the link below to know What's New in this version;
What's new in WaterGEMS CONNECT Edition Update 2.3 – Build 10.02.03.06
If you are interested in our solution please reach out to our Sales Team by submitting the below request form;
Sales Contact Request
Happy Modeling.
Yashodhan Joshi
Sounds good, I have waterGEMS, I will import it and see what it thinks. Thanks for your input.
