is it possible to export labels (with calculated pressure / velocity / flow etc.) from WaterGEMS / SewerGEMS into i-model format and to show them in Bentley View CONNECT Edition?
Hello Aleksandra,
Bentley Technical Support has had a recent conversation with one of your colleagues (Jakub) regarding this same question. In the Standalone version of WaterGEMS and SewerGEMS, only the model elements are exported to i-model. If you use the "For MicroStation" platform, the annotations will be included with the exported i-model. This is documented in the following wiki article: Annotating elements in an i-model
Answer Verified By: Aleksandra Tor
Thank You for your help!
