I am looking for clarification and deferences when doing the model using EPA SWMM; so if I am using PCSWMM , InfowSWMM and Bentley SewerGEMS (Explicit EPA SWMM) to do a model network for a stormwater network, will be any discrepancy in the output since all of them using same engine (5.1.013)? if yes what is the discrepancy percentage and how will affect the design of the network?
Regards, Mohamad Azzam
Hello Mohamad,
As of SewerGEMS and EPA-sSWMM, latest version of SewerGEMS uses EPA-SWMM 5.1.012 solver, so results between these 2 should match.
If you are seeing results that don't match then please provide the model files (.stsw, and .sqlite) and let us know what results appear to be inconsistent.
The following article lists the versions of EPA SWMM used by each version of SewerGEMS and CivilStorm.
EPA SWMM solver versions used by SewerGEMS and CivilStorm
Sushma Choure
Bentley Technical Suppport
Hello Sushma,
I am asking GENERALLY only, the programs using EPA SWMM engine as your products (SewerGEMS) and other ones as Infoswmm, PCSWMM, XPswmm ...etc. so since the engine is the same (native EPA SWMM), will be any difference in the output? I am asking about technical opinion from your experience about the hydraulic results.
From other aspects; I know it is different as to how to present the data, how to do input, how to create a report and other things.
I would appreciate if Dr.Tom and Jesse can comment as well.
Regards ....... Mohamad
Mohamad,
There is no results difference between Bentley extended SWMM solver and EPA SWMM, although we have added many additional results. The difference between Bentley SWMM solver and EPA SWMM is that we added some additional calculation features, such as node head loss calculations, incorporating HEC-22 inlet calculations, H2S calculations, Tractive force, etc. We also added a transition stability enhancement with a new calculation option.
Ming Jin
Thanks Ming
Just to clarify, the SewerGEMS user has the option in our calculation options to use the EPA-SWMM solver to get the exact same results as SWMM or the Bentley SWMM solver that implements the enhancements that Dr.Jin implemented and mentioned above.
See the section "Solver Compatibility - EPA SWMM solver vs. "Bentley Enhanced"" in the wiki article that Sushma mentioned. The ability to choose between the basic solver and "Bentley enhanced" version was added in version 10.02.00.55.
